E1200 overclock when do i stop?( i know chips very)
Sathsayin
Ok so here goes i have a e1200 and a GIGABYTE GA-73PVM-S2H
this is everything in my system. i use for gameing and school work i run my ac at 72c
* 1 x G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ - Retail
* 1 x Intel Celeron E1200 1.6GHz LGA 775 65W Dual-Core Processor Model BX80557E1200 - Retail (stock Cooler) overclocked now 2.0 with only 4 degrees temp diffrence
* 1 x Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
* 1 x GIGABYTE GA-73PVM-S2H LGA 775 NVIDIA GeForce 7100 HDMI Micro ATX Intel Motherboard - Retail
* 1 x Antec earthwatts EA430 430W Continuous Power ATX12V v2.0 80 PLUS Certified Active PFC Power Supply - Retail
* 1 x Antec Three Hundred Black Steel ATX Mid Tower Computer Case - Retail
128mb 6600gt gigabyte 8 pixel pipes with 3 vertex shaders no ext psu adapter runs from the board
$338.86 total in january 15, 2009
I have 500 budget with 160 left for video card I want to wait untill the next generation so that i can get a better deal but im tired of waiting plus the age keeps growing on my setup.... so here is the thing. I ran a vidoe card my buddy had in his computer can't rember what it was for the life of me but he said i needed a 550 watt psu to run it but ran it fine. He has a cpu that was probably 2x the juice so.. here is the thing. I would like to know how far i need to push my cpu in order to run a video card in the 160 budget.. while getting the best card for 160 dollars max. where do i need to stop. i hope i will get a uesd q6600 at the end of 09 ... but thats a far time off so maybe not. with that aside how much do i need to overclock my cpu to keep up with the gpu that 160 can buy!
please answer me back i have a 6600gt and have no clue my gpu is the bottleneck now. ive calculated that i use about 220-260 watts systems wide at max
I would get a E5200/E6300 (I don't see it on gigabyte official cpu support list) with Xigmatek Dark Knight and XFX 4870 from newegg.
thnaks for the fast response.
i can't acutally get both at this time. only video card. i understand that my cpu will bottleneck anything i get. so here is the thing which card would 160 buy that my cpu will max out oc on stock i imagine aroun 2.4 or so on stock. i have an antec 300 with all fans slots installed. 2 in front and one on side and 2 stock that come wiht it. or just the max taht my antec 430 watt psu can handle? because at the end of the year i hope to get a q6600
You should be able to get a newer 45nm quad core instead of the q6600 for pretty cheap at the end of the year. Try for a 3.0 ghz overclock, and bring it down if it gets too hot.
The best card you can get for $160 is either the Radeon 4890 or Geforce gtx260, depending on your preference. I wouldn't worry about bottlenecks. Faster is always better.
kk cool sounds good which one would you get and why out of the 2 cards. i like nvida becasue ive never had a driver crash but to me ati just always seems to look better. but i can definitly tell that 2d is done diffrently on an ati card for some reason seems to just be diffrent somehow.
ok so here goes i orderd this today for 161$
ECS NGTS250-512MX-F GeForce GTS 250 512MB 256-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail (instead of the gtx 260 are something more power hungry becasue my freind restressed to me the power requirements etc. and the cpu .)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814134064 119.99
Nvidia Gift Call of duty - World at war - OEM
Item #: N82E16800999088
http://www.newegg.com/Product/Product.aspx?Item=N82E16800999088 49.99
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134 26.98
ARCTIC COOLING MX-2 Thermal Compound - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186020 7.98
Nippon Labs 15 ft. USB2.0 A/male to B/male cable
Model USB-15-AB - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16812816019 7.99
and 58 dollars off with bundle deals leaves me with 160.94
so i need to know with this graphics card where exactly do i need to overclock this cpu to max out my gpu. if i need to get another proccesor as i think i will then cool. gives me a reason to upgrade. But as of now im stuck on the e1200 so where exaclty do you think i need to land her speed in order to not overdo it and prematurely overheat her ass. please help me im not that good of an overclocker. right now i have here setting at 2.1 stable intel burn test on stock sink with 5 case fans at 48c (max never goes above) under load passing perfectly. 28c off load. help me out as of now i don't have anymore cash.
I would get the other $13 and get the dark knight as it better cooling and is complete all in one with brackets for am2+, 775 and 1366.
oh shit i saw the hdt 1283 but not that one thanks... i fiugred it was like 50 bucks plus the bracket and other stuff thanks.
edit after looking im going to stick wiht my origignal becasue the freezer 7 was 26 with free shipping the other is 39 wiht 8 dollar shipping plus i didnt see the brackets which doubles the price so for nothing more then a few degrees in heat which i could spend that extra 25 on something else benificial thanks though.
edit/ yet again im unsure if this comes with the brackets its not in the pictures. did you see this deal at newegg.com it_shiro? are am what am i missing also i reread and see 3.0 ghz for the cellly from a post above my mistake! thanks for that answer. now im just debating on the cooler. I love this game
aight canceld and reorderd everything except freezer 7 pro now have darkniight instead i take it that it has the the brackets and everything right?
thx for the help.....
now all i have to do is get a uesd cpu that will max out this gpu later.
I dont think you really need to worry about bottlenecks. I'd rather spend the extra $30 and get the GTX260. It's much faster than the GTS250.
whats the power requirements for the gtx 260 vs the gtx 250 im kinda worried about it vs the gtx260 i understand the gtx 250 is a 8800gt-9800gt-9800gtx then slimed down and optimized into what it is now? where as teh 260 is newer tech but has more power requiremnets and i just don't want to put a strain on my psu and it die later takeing my system with it!
GTS250 is a horrible card for the price. If you are worried about power get a Radeon 4770 HD.
http://www.tomshardware.com/charts/...009/Sum-of-FPS-Benchmarks-1680x1050,1197.html
I was just going off of this I wish you wouldlve replied earlier do you think i should cancel my order.
http://www.tomshardware.com/charts/gaming-graphics-charts-2009/compare,1197.html?prod[2465]=on&prod[2482]=on
most games if you compare the two cards the nvida gets 2 times the frames it seems to be killing the 4770??? The specs seem better but gameing says otherwise are they using an outdated driver are something?
GTS250 = HD4850 but usually costs more. Actually, your buy might not be so bad if you want the free game and if you get the rebate.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131140
HD 4870 512 MB for 125$
4770 doesn't get killed by the GTS250. It provides similar performance (although it does perform a little worse). Also, it consumes 1/2 the power of a GTS250 and overclocks like crazy.
You don't need to worry about power. The EA430 is enough for most non-i7/sli/crossfire rigs.
Thanks I appreciate another opinion. When i had bought the ea430 I was inspired by tirades and danny they both said this will do fine for a similar build.... I kinda took the impression that power was overated to an extent and only if you have a good psu.. like this one. Anyhow if i ever upgrade it in the future it will be a corsair 750 (the good one i think its tx750) anyway i got my darknight the call of duty world at war and the mx2 in. but before throwing it in i thought I would take the time to show temps Idle/load at stock 1.6 on stock sink then overclocked. then i will throw on the darknight and mx2 take pics and get temps for them stock and oc . I'll take some pictures to just to see how far i can get it up to. Give me something to do since my card doesn't get here untill the 30th...
