Okay, so I had a sudden influx of unexpected cash. Much of it is going to pay off my credit card bills, but some of it can be spent on an audio upgrade. I'm trying to decide whether it's worth upgrading from my Soundstorm mobo to a E-MU card, and if so, which one I should choose. My current setup is:
Soundstorm digital coax output
Onkyo TX-SR501 Receiver
Pair of Klipsch RB-35 bookshelf speakers
Velodyne VX-10 Subwoofer
It's a nice little setup that I just finished putting together. Everything sounds pretty good to me, although I know there's plenty of room for improvement. I'll be building off this system for the next few years, constantly upgrading. It will probably evolve into my main system once I graduate (still a freshman now) and enter the real world. Anyways, I figure the weakest link in their right now is either the output from my computer or the receiver. The receiver would cost too much to upgrade, so I'm thinking the best idea is to go with a new sound card.
My budget is up to about $200...it can be stretched a little more than that, but I would prefer not to. I would also prefer to spend as little as possible. That being said, if there's something out there signifigantly better than what I'm considering for a little more than my budget, I'd like to hear about it.
I know my current setup produces sound that's on the "bright" side. I like that. I'm happy with the brightness. I'd rather not get any more bright though, because songs with a lot of treble like the Beatles are getting very very bright.
I will be using the digital output on whatever card I buy, probably coax since I already have a nice cable for that (my cables are custom made by my friend). I know Soundstorm is currently the only card that can encode to DD 5.1 on the fly. I will eventually be upgrading to a 5.1 system, but that probably won't happen for at the very least, 2 or 3 years. So that's not a huge deal for me right now. However, if I do upgrade, I want to know if I will be able to switch between Soundstorm and whatever card I buy, so that stuff that needs to be encoded to 5.1 can be played through my Soundstorm, and other stuff like music can be run through the new card.
I mainly use my system for watching movies and listening to music. Music is much more important to me, since most of my movies are Divx/xvid backsups and the sound isn't fantastic on them anyways. As for music, I listen to a lot of Alternative and Acoustic rock. A little bit of pop rock, a lot of jazz (so a warm sound isn't necessarily bad, but I just seem to like my brightness). That's about it. Bands I listen to are something like:
Guster
Dispatch
O.A.R.
Train
The Wallflowers
Counting Crows
So, basically I'm looking for a card to improve the quality of my music. I want to know if it's worth upgrading from Soundstorm to an E-MU solution. I've heard of several new cards on the horizon, such as an add-on solution from Nvidia, and new cards that will be able to do what soundstorm does. Quality however, is far more important than features at this point. My Klipsch speakers bring out every flaw in my system, and I'm looking to eliminate them one by one.
I've also heard about modded E-MU cards...where can I find more info on these, and approximately how much does it cost and what are the benefits?
As a last note, I've heard of a lot of compatability issues with the E-MU cards. Should I have any trouble in Windows XP, with an Asus A7N8X Deluxe mobo, Radeon 9800 Pro, and Athlon 3200+ processor?
Thanks for the input guys, sorry for the long post. I tried to be as detailed as I could.
Guster
Dispatch
O.A.R.
Train
The Wallflowers
Counting Crows
