Dynamically Augmenting Wheel System
I could just see the tires snapping and the car slamming to the ground.
I think it would have a rough ride. They put air in tires for a reason. Solid tires were tried early and didn't last long.
I dont know about you guys, tires falling off are happening, and actually it have most likely happened to 20% in Norway.
We change tires atleast twice a year, and people does'nt tighten the bolts after a week after putting the tires on.
but, still cool concept.
*wonder when the good old tires dies out for some high tech levitation technology*
If it aint broke dont fix it. I watched a great video the other day of cops trying to stop a stolen corvette by putting spike strips down. They didnt realize the new vets have the never flat tires and just kept on rolling :D
It wouldn't work because you create a discontinuity during the rolling force against the ground. Furthermore the sheer forces multiply greatly as a function of centrifugal forces would tear this thing apart.
That's as gay as an easter bonnet. WWII torsion bar meets A frame.
Reminds me of the "Smart Wheels" in Snow Crash by Neal Stephenson...... Y.T. had the on her skateboard and Hiro had them on that bad ass Motorcycle.......
Good book....
That is the dumbest idea ever. I think the Michelin tweel is a bad idea, but this definitely takes the cake.
Current suspension systems can keep the tire orientated up and dow on the road easier than agmenting the tires shape. This is just a waste of time. If they could augment the tire that easily and make it reliable then make the tire spread the surface out on the ground at low speeds for better traction. sections could be moved out at the front and back of the tire and the tread sections would pivot to face the ground. This would be like 3x the contact area. Of course just having a bead-lock tire and the abbility to inflate and deflate on the go could do basically the same thing.
Nope, around here tires falling off of cars isn't an every day occurance.
Good book....
Lol you beat me to it. And yea, terrific book. I just finished it.
looking at the above posts... can't see much thought really went into some of the responses.
The idea is sound although the article sucks and really misses quite a bit.
The major problem with the concept is ... WHY???
What they are trying to accomplish could easily be worked out by a wide wheel stance, lowering the center of gravity or active sway bars... I'd like to say it looks cool but in reality it doesn't.
THe biggest question is why did this ever make it on to the drawing board.
That was the whole point of the design - to look cool. It's a portfolio piece, and will never make it to production, much like 50% of the stuff that makes it to tech blogs. :)
The idea is sound? How so? The fact that car is going to vibrate itself into pieces at higher speeds? I'm sure it won't hold up to the elements. Hell, I'd love to see how it handles rocks that get flung into it. We've been all there, where a semi in front flings rocks at your car. What happens when a large gust of wind hits your car?
If that little model is how they actually want the car to be, I expect that half shaft to shatter in no time.
they seem to have gotten the physics in weight transfer backwards. the car would 'slide' over the top of these magic tires making it more unstable as shown in one of there pictures.
thinking outside the box is always nice,
but this isengineering fail it would seem.
clarification:
they show a model car cornering to the left with the weight transfer also moving to the left which is incorrect.
I think they address this in the article when they mention it would increase the propensity for a 'rollover.'
nice.
all that to move the CG a bit? why not just move the entire axle side to side with hydraulics for 1 100th the price.
I'm a big advocate for the WHY? principal. However, it won't work. Period. Even if they could get it to work, it would be so impractical as to render it effectively useless. The torsion/slide shifts coupled with the rolling forces alone render this thing a disaster. Some ideas look cool, sound cool, but in reality aren't cool. Not every idea needs to be explored or voiced.
Or just make cars lower, better suspension, and wider tires. Oh wait...we already did that. What was it they called them? Sports cars or something.
Because that would shift the entire chassis from a fixed chassis to a floating chassis.
