Dynamic IP?
Status
Not open for further replies.
Funky_Junk
Hi,
1. How do I know if I have a dynamic IP and not a static one.
2. If I have a static IP, is there anyway to change it to a dynamic IP?
Thanks. BTW, im using cable internet with a router.
if your internet connection is a residential connection, you most likely have a dynamic ip address. Static ip address is more for business with a domain.
I have residential Road Runner and I've had the same IP address for almost a year now.....when I got road runner.
I have a residential cox connection, but how can I find out. Im trying to find out because I want to change my IP address and I heard if you have a dynamic IP you can change it just by unplugging your router over night.
you may be able to changed it by doing or setting a DCHP release from the router....
you could always call up your ISP and see if they can change you ip address
How about just go into the router and look at the WAN IP, then reboot router and see if it changes?
Why want dynamic anyway? Did you get naughty and got IP banned?
That wont tell you for sure though. IPs are on a lease in most situations so the ISP would give you the same IP back when your router came back online. Leases can vary from a few hours to a few days.
I know I am on dynamic, but my IP will stay the same for a week or so even if I reboot my router :p
Easiest thing to do is call your ISP, they will know. Most residential is dynamic, but some are static.
Is there a setting I can look for or some sort of tool I can use to find if my IP is dynamic?
Did your ISP actually give you a certain IP address you had to manually enter into your router? If not then you have a dynamic IP assigned by them. The vast majority of home ISP's use dynamic IP's, and I'm sure that's that you have unless the above is true.
Actually, it depends on the ISP. Most cable providers in my area hand out statically assigned dynamic addresses. So I'll always get the same address when I send out my DISCOVER packets, but it's still via dhcp.
Eh, most likely they are just keeping the lease info server side and handing out the same IP since it's still associated with that MAC. Change the MAC address though and it would probably give you a new one. Some DHCP implementations keep that information and only reuse a previously assigned IP when it has exhausted the block and comes back around from the top to find a currently unused one.
Status
