I was defraging my os drive and and another harddrive and my system crashed during it. After rebouting it would freeze starting up. I repaired the windows instalation and it still frooze i did a new one and it booted up slowly. When i installed my sata raid drivers for the mobo it would freeze up again. In diskmanagement it would show the drives as failed. Is there anyway i can restore these drives without losing anything on them? I tried to reintialize them and it failed also.
The os drive is not a dynamic drive.
1 other drive is and it's on a highpoint ata controller on the mobo,
and 2 other drives are on a sata controller on the mobo and those are setup so they add the space together or share space forget what raid that is.
If i disable the 2 controllers in the bios i can boot into windows, i tried using maxblast and datalife tools from maxtor and western digital and western digitals freeze up and max blast freeze also. Any help would be appreciated. The mobo is a epox 4pea+, and the drives are 2 wd and 1 maxtor.
