Dying PCB
Discussion in 'Cases & Case Modding' started by tmillszero1, Aug 6, 2011.
  1. tmillszero1
    tmillszero1 Limp Gawd
    223
    May 11, 2011
    Quick question for the [H]? Has anyone successfully dyed PCBs for their builds? I’ve seen a few threads on other forums, but nothing too specific about it. My “blue” PCB on my EMU 1212m is really getting on my nerves. (Circled in red below….)
    [​IMG]
  2. Kamainae
    Kamainae [H]Lite
    72
    May 3, 2009
    Spray paint that motherF****. But use a nonconductive spraypaint.
  3. Dudeyourlame
    Dudeyourlame [H]ard|Gawd
    1,085
    Jul 23, 2004
    Could make some sort of shell that goes over the card to hide the fact its blue, or spray paint it works like kamainae said
  4. tmillszero1
    223
    May 11, 2011
    Spray paint was a great idea, but... It is kind of hard to score the pcb then paint. There is a bit of residule "stuff" that won't allow the primer and paint adhere.... Just tried it on an old mobo tonight... hmm... things are not looking up.... maby an acid wash? Then primer/paint? (A shell would work for the sound card, but, I plan on ditching the daughter card for a break out box....The bottom card will be ditched)
  5. Shata
    Shata [H]Lite
    101
    Oct 14, 2006
    Someone has another spare card laying around maybe try some Krylon fusion paint maybe It will take on the residue.
    Although like mentioned...Id be pretty carefull testing it cause of conductivity...
    Best thing would be is take thin sheet of plexiglass cut it to fit card, look to see if you have 4 spots on card where you dont see any traces and Dremel through it, Use small plastic spacers and paint plexi black and put it on with bolt/nut type of idea. (Just fyi, pcb's are multi layer now days so if you dont see any doesnt mean u wont hit nothing - your gona take risk doing it)
  6. Sebastianem
    Sebastianem n00b
    59
    Jun 3, 2011
    Agreed. Try an old WORKING card, paint, then see what happens. Be sure you won't miss the part. Good luck and let us know!
  7. tmillszero1
    223
    May 11, 2011
    Sure will! Thanks for the ideas!
  8. geant90
    geant90 Limp Gawd
    464
    Aug 6, 2011
    I want to see pics!
