Dying motherboard? Please help.
loft
I don't know where to begin, so I'll just jump right in with the problems.
Last Wednesday my system crashed, hard. WinXP BSOD'd and upon reboot I received an error message stating that the System32 folder could not be found. I assumed it was a virus that my AV missed... but read on. Okay, simple enough... reinstall Windows and start fresh. Decided to install Vista Ultimate, and things were going fine.
It wasn't until I started to install applications that I noticed some issues. WoW, for instance, was giving me the dreaded install errors 2 & 38. At that point, I figured I'd test out the ram and see what came up. Using memtest I saw roughly 300 errors in under five minutes. Alright... run to the store and grab some ram to hold me over. Plop it in the system, start with a memtest to see what came up. Perfect, no errors in 4 hours. Mind you, I'm running it at stock clocks. So, I boot into Vista and decide to try and reinstall WoW. Deleted temp files and started installing. Same errors pop up. At this point I searched around to see if there were any diag tests I could run on my hard drives. SeaTools reports no errors using all three tests (Basic, Advanced, Acoustic?) I don't remember the exact names.
At this point I've decided to take the drives out of Raid0 and set the bios to recognize them as IDE. Reinstalled Vista, same problems. Updated all drivers and am still getting corrupt file errors.
By now I'm getting a little frustrated. Hop into the bios, enable the second raid controller (Marvell) and hook my hdd's up to those sata ports. Reinstalled Vista and bam. Same thing. I've tested the hard drives in another system in Raid0, and not in raid and they perform fine. No corrupt file issues, etc.
What do you guys suggest I do now? Are there any other tests that I could do to see if it is in fact the motherboard dying? System specs are in my signature. Thanks in advance guys... I really appreciate any help.
Are there any other programs that are also messing up or is it only WoW?
Other things you may want to do:
1. Physically check the board to see if any part of it looks bad. Watch it while running to make sure the fans are spinning.
firefox, thunderbird, and aim are the only other apps i've tried using. They all crash. All fans are functioning just fine.
Just checked and the temps are fine. Is there any way to check for data corruption at the sata controller level?
Spinright is the single best HDD diagnostic tool and data recovery program ever made. It attacks the drive at a pre-os bit level, which gives you alot of things to look at. If your HDD has a problem, spin right will find it. Now that said its expensive, if you ever repair peoples computers and think you might be wanting to diagnose other HDDs, pick up this program
If you ran each drive in separation and tried an os install to each, independently, and still had a problem, then its not likely your drives. So Spinright probably isn't the best solution.
Memory would have been what I looked at next, but the fact that it faulted, you replaced it, and its still faulting gives us a very very good indication of who killed mr Os:
Your motherboard/chipset.
Do you use an NIC or Soundcard? if no to either, are you experiencing any networking or sound troubles? What is your PSU? I don't suppose you could swap out the mobo (heh, always a bitch, but its the definitive test).
Thank you so much for responding.
You know, I've actually been having some very minor lag spikes which I just attributed to my girlfriend using her system.
Utilizing onboard nic & usb headset at the moment... PSU is a modular Hiper 580w.
I don't have the ability to swap out the motherboard as this is the first Intel system I've built since the Celeron 500. I'm thinking about ordering an Abit P35 Pro, however.
Given the fact that I've now (allegedly) destroyed a third set of ram, I'm really thinking it's the motherboard. Just threw it in, responded a little while ago, and then started getting random crashes.
Here's to trying to do more research on the P35 chips.
/thread
Ordered the Abit IP35 Pro tonight. Hope all goes well with the install and first boot.
Thats the kind of mobo I got and so far its worked perfectly. I dont particularly like the way the sata/ide ports are placed though, But its no big deal. Also you cant SLI with this board as far as I know.
I already sent the Crucial sticks back to the 'Egg. The other Kingston ram I got on Saturday (to hold me over) will be tested on the board as well. If it works fine, I'll use it in a build for my mother.
SLI is an nVidia thing... at least from what I've researched. I could care less about SLI though; as my 8800GTS does everything I need it to (WoW, CS:S, Crysis soon)
