Dying hard drives....
Dangman
Ninja Editor SuperMod
In the past four months, I have had five hard drives die on me. I'm pretty sure thats not a good sign.
Death toll:
WD 250GB PATA (2 year old)
Maxtor 60GB PATA (3 years old)
WD 120GB PATA (1 year old)
Seagate 300GB SATA (2 month old)
Hitachi 160GB SATA (3 month old)
Anyway I was wondering if there is an explanation as to why all these hard drives died so quickly. My friends believe the main problem is heat but I believe there is a different reason because I have a five year old Seagate 6.4GB in the same case as the other hard drives, yet it has never failed on me.
So is there any other ways I can stop my hard drives from dying?
Please post:
System specs (CPU, vid card, anything you can think of with a chip on it or a power connector leading to it)
Brand, model, and +12 current rating (in amps, on the label) of your power supply
How many drives you have installed at any one time
What is cooling the drives
sounds like a power supply problem. im not 100% sure if the v1.2 (or is it 1.3? cant remember) delivers power differently than 2.0 (and above), but i am almost certain the v5 and v12 deliver power differently to the drives. what PSU do you have?
You're mistaken in your assumptions here. That old Seagate spins at a lower rate and produces less heat internally, therefore it can generally withstand higher ambient temps than today's 7200 and 10000rpm drives. Those old things are just plain workhorses.
@DougLite and protias
The specs are in my sig, the PC. As for the power supply, it came with the case, a X-Dreamer II. Here's a picture of the P/S:
I usually have 3 hard drives installed at any one time. 2 PATA and 1 SATA. There's a 80mm intake fan right in front of the hard drive
@davidlem
Thats right. I completely forgot about the hard drive's RPM. It is a 5400RPM. That would explain why that Seagate hasn't died yet.
Well now I wouldn't draw any absolute conclusions regarding that 5400rpm Seagate. I just didn't want you trouble-shooting while misinformed.
PSU is definitely the problem. I have a Turbolink PSU sitting on a junk pile in my garage, as it killed a WD1200BB in less than a week. Aspire's PSUs are among the worst PSUs out there, especially the ones that ship with their cases.
http://www.hardforum.com/showthread.php?t=974240
Head to the PSU forum and check out their stickies to see abotu a replacement. A good Antec, Fortron/Sparkle FSP series, or Enermax doesn't have to be expensive.
http://www.hardforum.com/showthread.php?t=1000883
@ DougLite
Ahh man, thats good to know. Actually wouldn't have suspected the P/S. Thank you for your help.
@ -(Xyphox)-
I actually have that program. Though it only kept the hard drives running for another two weeks or so, now that I know that the P/S could be the problem, I may have to recheck my hard drives when I get a new P/S
Danny Bui said:
@ DougLite
@ -(Xyphox)-
Spin-Rite best program out there for drives, glad to hear you use it :D
@davidlem
Wow, not many safety test lab logos on that sucker. My psu has at least 5 i think.
