I am running XP Pro 64 bit and I am not sure if this is a big problem or not. If i run dxdiag as 32bit it detects the correct CPU but not the correct clock speed, and if I run dxdiag as 64bit it detects the CPU as an AMD64 and not an intel core I7, but shows the correct clock speed. Could this be a problem with confusing programs such as games and cause them not to work correctly?
I am posting dxdiag 32 and dxdiag 64 system info and diag notes if other info is needed let me know.
DXDIAG 32 DATA FOLLOWING...
System Information
Time of this report: 3/4/2009, 10:44:45
Machine name: WILL-TNVX94IQ2A
Operating System: Windows XP Professional x64 Edition (5.2, Build 3790) Service Pack 2 (3790.srv03_sp2_gdr.080813-1204)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (8 CPUs)
Memory: 12278MB RAM
Page File: 348MB used, 13463MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.3790.3959 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DXDIAG 64 BIT DATA FOLLOWING...
System Information
Time of this report: 3/4/2009, 10:45:19
Processor: AMD64 (8 CPUs), ~3.8GHz
Memory: 12278MB RAM
Page File: 353MB used, 13458MB available
DxDiag Version: 5.03.3790.3959 64bit Unicode
DxDiag Notes
Notice under system info that the processor info is different. The actual is Core i7 920 (2.67Ghz) but overclocked to 3.8GHz. I have run various testing programs to test overclock and system is very stable.
System Information
Memory: 12278MB RAM
DxDiag Notes
System Information
Memory: 12278MB RAM
DxDiag Notes
