I'm making the move to the 8800GTX soon, but am unclear as to the DX10 situation with XP.
Is DX10 needed for the card to run even if on a DX9 system?
I've seen [H] do GPU reviews with DX10 cards using DX9... so I'm assuming it would work fine?
If you do install DX10 on XP for the card, how do you go about it? Does it cause any problems?
I've seen some say you have to install DX10, but from certain [H] reviews I've seen, they used DX9c.
As for Nvidia, which driver(s) are the best to use right now?
I haven't used an Nvidia card in a few years, so I'm bit behind the game.
Any info appreciated, thanks.
