DX10 ATI problem...
I have A newly built pc. Hardware is phenom ii x6, 4gb corsair dominators, gigabyte 890fx board and an hd 5850. I have ccc 10.4 installed. My problem is this, every time i try to play a game at 1920x1080 on my acer x233h with dx10 enabled in game my refresh rate gets set to something my monitor does not support. I have read multiple things by searching google for my problem and it seems other people have had the problem before but i cannot find a fix. I have attempted to force a proper refresh rate through ccc, ati tray tools and in windows itself. I built the computer for the latest and greatest and this is a pretty frustrating problem. If anybody has any ideas i would appreciate any help. Thanks
THe most common fix is setting the "VSYNC" to ON in the game's graphics settings. This also helps with shearing or tearing on LCD monitors.
I have tried playing with vsync but to no avail. Also, i forgot to mention this ONLY happens with 1920x1080. Other resolutions work fine although i only tried two or three others. I wi check a few more when i get home
Could this be an issue with the CC10.4 driver set? You may want to install a previous vid driver to see if that solves your problem.
I have tried all of the above suggestions and have had no success what-so-ever. Still the same problem, every time I change in-game settings to DX10 I get the "input not supported" message bouncing around on the monitor. No one else has any ideas what could be happening?
I have solved the problem in Company of Heroes with DX10. I used the command line in the shortcut "-refresh 60" to force 60hz refresh in the game and, lo and behold, success!. I'm going to try this with my other DX10 titles.
This has to be a driver issue, can you confirm you've tried previous drivers such as the 10.3's
When installing them it might be worth uninstalling the old drivers completely, using a driver cleaner in safe mode to kill all old driver files, then do a fresh install the 10.3s
I did this exact thing for 10.2 10.3 and 10.4a for the hell of it. Still the same problem in each case. It's clearly a refresh rate issue i know i have herd ati is strange with their 59.97 hz thing. But like i said, when i use the shortcut command in the company of heroes shortcut "-refresh 60" the game runs fine in dx10
Sounds like your system might be incorrectly reporting what display modes your monitor is capable of. See if you can find a driver for your monitor. Failing that, you might be able to hack together your own monitor.inf.
