Ok, the Dell monitors are finally on the way, my new MONSTER pc is built, now I can relax ... oops ... I forgot, theres one last thing to work out. LCD's are replacing a CRT, which I hope to move to a different PC. The older PC only has DVI ports on the graphics card. Please correct this assumption of mine. Some1 once told me that if you have a graphics card which only has VGA, and an LCD that is only DVI, an adapter is available ... but the reverse scenario can't be done ... where you have a vid card with only DVI and a monitor with only VGA. Is this true? Is there an adapter I can get that will allow me to put a VGA only CRT onto a PC which only has DVI outputs?
Now I need to learn overclocking
Will update sig with new PC hardware stats.
