DVI-VGA adaptor
Zatos said:
Is there any cons to using one?
Yes, if you're running a higher resolution on a longer cable you might see stuff like ghosting/shadowing ect...it all depends.
Only one way to find out though ;)
Get a good quality one, shielded if running anything higher than 1024x768.
