Colonel_Panic
- Oct 5, 2009
When I start to use my new PC, I'm going to be sharing my 25" ASUS monitor with my MacBook Pro. To use the computers properly, I need a KVM switch.
I'm buying the Logitech MX5500 Wireless keyboard/mouse combo, but I want to make sure my KVM switch is compatible. Can anyone recommend one? DVI isn't strictly required, because MBP uses VGA and my PC uses DVI, but I'd like to have this connectivity if possible. Most of the switches I've looked at don't use separate power supplies, which I think will affect the power available to the peripherals.
