I bought a Dell Optiplex FX170 (which is a thin client) off ebay. I know its booting up because the power LED comes on and when i connect headphones to the audio port I can hear the windows start chime (it has windows embedded as the default OS).
It only has a DVI-I port. I tried it with two different monitors. unfortunately both are VGA only monitors. so I had to use a VGA adapter. looking at the chart below, first adapter looked like a DVI-D Single link male interface. 2nd adapter I tried looked like a DVI-D dual link male interface. Both adapters failed on both monitors. on my second acer monitor I got the error "input not supported" using both adapters
upon reading up on DVI seems I will need a DVI-I Dual link to VGA adapter. dual link because it needs to carry the analog signals over to VGA. Just want to verify I am correct before I go out and buy the adapter.
