Mar 21, 2010 #1 S Swede88 Lurker Joined Nov 30, 2003 Messages 657 I'm trying to figure out the best use of cables if you have: Monitor - DVI and VGA inputs Video Card - HDMI, DVI outputs Do you simply use a DVI cable between both? Or would you use an HDMI cable with a DVI adapter for the monitor?
Mar 21, 2010 #2 B brumwald Gawd Joined Aug 1, 2006 Messages 598 In this case DVI and HDMI is the exact same thing. So it doesn't matter.
Mar 22, 2010 #3 E evilsofa [H]F Junkie Joined Jan 1, 2007 Messages 10,078 Bedpan Commando said: Do you simply use a DVI cable between both? Click to expand... Yes.
Mar 22, 2010 #5 A akwok Limp Gawd Joined Feb 19, 2005 Messages 158 Oversimplifying here, but HDMI is essentially just DVI and an audio stream jammed into one cable.
