I am using a Radeon 9600pro with a FlatPanel monitor. Ever since Catalyst revision 3.9 and up, the DVI Connector on the card would not work. When Windows starts, it BSODs (which I can't see because the monitor is shut off) and then reboots. About 1 in every 10 boots works successfully.
After yelling and screaming at ATI "techs," I forced them to create a website, although there is not much there:
http://www.ati.com/support/infobase/4497.html
My System will work with the newer drivers while connected through the VGA connector, which is curious. I am experienced and always uninstall before installing new drivers, I even format and start from scratch with no luck. Anyone else experiencing this problem or, even better, anyone experience this before and fix it?
BTW: I'm buying an NVidia as soon as I get paid!
