if you're experiencing this issue from boot, as well, try these:
1.) power down computer, completely. turn off monitor. turn monitor back on, then power on the computer. does the display stay black, say no input, no signal etc?
A: likely that your monitor is not capable of auto-sensing an input signal, and then switching to that source. you may have to go into the OSD and select the DVI connection as the default input, instead of the VGA (since that's what you were using before).
2.) power down computer, completely. turn off monitor. turn computer on, then turn on the monitor. do you see the image now?
A: your monitor does support auto-sensing, but you DVI may not be the default input, and thus, has to be hot-plugged, or the DVI has to be set as the new default (since you were previously on VGA cable).
Also, the manual, or tech support line (if you like being on hold), will provide more useful information, such as what features your screen supports, and the recommended order of operations for usage. It's going to take some effort on your part. There may be nothing wrong at all, with the card, the cable, or the screen. Could be as simple as a particular order of execution.
