DVI Problem?
AmyR
I have a Viewsonic VX2025wm monitor and a Gigabyte Radeon X1300 Pro graphics card. Yesterday when I turned my computer on heaps of my pixels were going crazy.. like, most of the screen was just flashing blue. I tried using one of those pixel-unsticker programs but somehow that made it worse. Anyhow, I took notice of when it was doing it and in what areas and decided it was not my monitor, it was the graphics card. Since then I've switched it to VGA and it seems to be fine, but when I switch it back to DVI it goes crazy again.. any ideas?
It's possible your DVI cable somehow got damaged, try a different one if you can. Also, see if you can find another video card with DVI to test with your monitor. If you can do either of those things, the result will tell you where the problem is.
