A
altcon
Guest
Well, I found out my X1800XT wont show a picture when using the DVI on the right.
It will only show it on the left DVI connection, even if I shut the PC off completely and then switch connections.
If I switch it back to the left after windows has booted it just shows the desktop as usual.
From my experience, the bios screen is supposed to post on both DVI's -no matter what.
Any ideas of something to try b4 RMAing it?
