DVI or VGA for Dell 2005FPW?
phatjedi
Are you guys using DVI or VGA outputs to your LCD monitor? Not sure if there will be a big difference plus or minus using either. Just wanted to see if it is preferable to use one over the other.
Thank you for your input.
intelbrain said:
IMO, DVI is the best for lcd, you get crisp images.
I feel that DVI is also much better visually than our old trusty VGA friend.
VGA = Julia Roberts
DVI = Eva Longoria
I've been using LCDs for years, big and small, and I have never noticed a difference in crispness between the two. VGA also has the advantage that there are a lot more adjustments. Having said that I use the DVI port on my 2405fpw solely so that I can keep the VGA port free to plug in my laptop.
VGA = Julia Roberts
DVI = Eva Longoria
Sweet anology!!!! :D
Thanks for the feedback folks. DVI here I come!!!!
