I don't know any LCD which is capable to real higher than 60Hz refresh rate.Will there be a big difference between 60MHz refresh and 75MHz?
While they might accept higher refresh rate input they just drop frames away, for example most LCD monitors accept 75Hz input (through DVI) at lower than native resolution but they simply drop every fifth frame.
For higher refresh rates we have to probably wait until really mature flat display technologies (OLED, FED/SED) replace slow liquid crystals and leaking backlights.
DVI will be clearer.
VGA still has some distinct advantages however:
Main one for me is the ability to do high refresh rates (85 to 120hz)
Secondary consideration is that scaled images look better on VGA/CRT. If you have a lot of games that run at different resolutions (800x600 to 1920x1080 and everything inbetween) then the good old analog signal often scales much better.
What do you recommend if I only play one game really? (WoW)
I run my resolution at 1280X1024 75Hz
Fixed. I doubt anyone could tell the difference between 75 frames per second and 75 million.![]()
Is that true for both Analog and DVI connections to the LCD?
I've run mine at 75 for a long time, but if it's true that it has always dropped to 60 than going from analog to DVI should be no trouble.
