DVI or HDMI hook up?
blert
So, just bit on the 37" Westy deal and was wondering what would the best way to hook it up to my pc. The Westy has both DVI and HDMI hook ups and my card is a 9800GX2 and that has both options as well.
Since I would use it mostly for gaming (if that makes a difference) which would be the best way to go? Or does it really matter and merely come down to preference?
I would say that it comes down to preferrence. I notice no difference between the two as they both trasfer 1080p. Could be just me though
I prefer HDMI because it's simpler to hook up. 1080p should be the same quality, but the only different I see advantage of HDMI is that it's capable of audio. I don't know if your Westy and GPU supports it.
