Hi there
I recently put together a new PC, hooked it up to my LG 20.1 LCD L204WT through DVI and all I get is a black screen saing "Digital Power Saving Mode". I hear the PC runing and going into Windows but I get no display just a black screen. My graphic card is a Asus Geforce 8800Ultra and has two DVI outputs, ive tried using both but without any luck. When I use the DVI to VGA adapter everything works fine.
Ive used the DVI on this monitor for over a year with my old PC and I also tried hooking up my old PC again with DVI to see if it would work and it did without any problems so I guess that means the DVI on the monitor is working fine. Ive tried a lot of tricks and methods to try and get the DVI working with the new PC but it still isn't. If anyone might have any clue to what is going on or how I may be able to fix this, please post and thanks in advance.
My Specs are:
LG 20.1 LCD Wide L204WT-BF
250Gb Sata HD
2gb ram
Msi Mainboard S-AM2 nForce 570 SLI ATX 2xPCI-E
530W Hiper PSU
If anyone needs more details on the spec ill post it.
My Specs are:
250Gb Sata HD
2gb ram
530W Hiper PSU
