My new 19 in. BENQ FP951 is connected to my pc with a dvi cable. The problem is the brightness and contrast controls on the monitor have no effect on either the brightness or contrast of the picture - throughout the entire 0-99 adjustment range. I thought this must be a monitor defect but have read some other similar complaints (not restricted to this model) so I'm thinking this may be a common limitaion of using the dvi connector. I can use the vid card software for this purpose but feel that since it is used by all members of the family it should work properly.
If its a monitor design defect I may return it for another model. It is used for fast games, movies, cad and photoediting and my budget is limited, so I want it all
I'm partial to the 19 in. size for easier viewing. Your suggestions on whether I should keep it or return it for another model will determine what I will do.
Thanks,
Thanks,
