DVI KVM Switches - 2 Port
RanceJustice
I was wondering if anyone could suggest a good, high quality KVM switch that uses DVI and has PS2 mouse and keyboard ports? Am I correct that KVM switches do not cause a loss of Video quality, nor responsiveness of mice?
I know these will be a little more expensive but I'd like to find a solid brand at a good deal. Thanks.
well, for starters... here's what i filtered out of newegg
Newegg search results
The only kvm i've ever used was just a regular vga w/ ps2, so i cant speak to picture clarity issues except to state the obvious and make sure it does at least the resolution you intend.
looks like these ones just do 1600*1200 at 60HZ. Enough for me, but maybe you need higher res.
Great. Thanks. 1600x1200x32 at 60hz is what I'm looking for at the moment. What I'm really asking is a direct line from video card to monitor is equal to the quality of video card > DVI KVM > monitor, provided the resolution is the same. I just want to ensure there's no "lag time" or signal degrading effects.
Whew. Those things arn't cheap but hey... I guess its worth it for DVI
I can warn against the Belkin unit. The design is terrible. The top DVI connector is too close to the top edge of the case, and its a real pain to get the connector in there. I had to swap around connectors before I found one that actually fit!
.B ekiM
I think you should ask yourself if you really need DVI on both computers. I mean most people have a main computer they do all their gaming, etc on and a backup machine that's used more as a spare, where VGA is just fine.
Well maybe I shouldn't say "most" people, that's how mine is. VGA is fine for my back machine, since all I'm doing is messing around in Windows, setting things up. Gaming and all general usage is done on my main rig.
