DVI issue with radeon 9700 pro
XeRo_Dark
for some odd reason its not letting me switch my primary display to my DVI port on my gfx card... i have the latest catalyst drivers from ati ... any ideas of what i should do? ...
where exactly is the option to make the DVI port your primary display out?
a screenshot would be greatly appretiated (though its probably un nessicary, pictures are faster to look at then reading :D)
Sounds like you're trying to run duals? Try running a single off the DVI first, see if that poses any problems.
I have an AIW 9700 Pro and had no problems with the switch over. It automaticly changed over to DVI.
