I just got my hands on a pair of IBM C220p monitors. I also happened to have a nice GeForce 6800GT dual DVI video card on hand. The monitors each came with a DVI-I->VGA cable, and each have a DVI-I (analog) and a VGA port. I'm under the impression that analog DVI-I is to be a replacement of sorts for VGA->BNC on higher-end monitors, but I digress.
Currently the cables (which seem to be okay, but they *are* stock cables) are connected to the VGA inputs on the monitors so the DVI ends are attached to the video card.
Everything is peachy until I hit 1600X1200, where I start to see what can only be described as a slight "glow" or "fuzziness" towards the edges of the screen when viewing text. Most people probably would never notice, but... yanno. Spend 10+ years staring at CRT and LCD screens and you start picking up on crap like this.
As this is nowhere near the monitor's max resolution and the video card seems to be pretty decent, I'm placing blame on the stock cables, or at least on EMI they could be picking up on and not sheilding against properly. I've not managed to find too many "true" DVI-I cables that don't suck (Cables with DVI-I connectors are standard but almost always have either digital-only wiring (missing the four prongs around the wide flat connector at one end) or have a VGA connector at the other end.) In fact, these are the only two I've found so far:
http://www.cablestogo.com/product.asp?cat_id=2030&sku=26948
http://www.computers4sure.com/product.asp?productid=1389902&iid=1252&Hits=4&HKeyword=dvi
(cablestogo.com has varying lengths, and single-link for the digital components. computers4sure.com's cables seem too sparse on details, but that's all I've found outside of cablestogo.)
Any thoughts on the merits of DVI-DVI over DVI-VGA, and on my selection of cabling so far?
