I'm bit of a newcomer when it comes to monitor set up, I currently have two Asus VS248H-P (one being used as my main connected via HDMI to the GPU) and the second one is on it's way, I'm curious as to if I need another HDMI cable to hook it up to get the HD experience, or will I receive the same HD experience if I used a DVI cable?
Also awaiting the release of the new Asus VG248QE 144hz for my main monitor, but don't know what it's going to be released since I don't really have the 27' VG with the 1920x1080 dimensions, might as well wait for the 24 if the resolution will be at that.
It's not really needed to have 3 144hz monitors, only the one that you use for gaming correct?
