Is there really a big difference? Both my video card and LCD monitor has a DVI connector and right now I'm only using a DVI/VGA converter on one side (Video Card) and the connection to my lcd is just from a VGA.
So just wondering...what would be the difference if I try to buy a DVI-DVI cable instead of DVI converter-VGA-VGA cable?
Right now it's like this:
Video Card - > DVI Converter -> VGA cable -> VGA Cable -> LCD.
Should it be like:
Video Card -> DVI Cable -> DVI Cable -> LCD.
And what's the difference if it's gold plated or whatever. Will my eye be actually able to see the difference?
Last but not the least...where can I buy those DVI/DVI cables, thanks.
Should it be like:
