On vista, you cannot extend your monitor (and thus not run a GPU client) to cards that don't have a monitor attached. The dummy plugs fool vista into thinking there's a monitor attached. XP (32 and 64) don't suffer from this 'shortcoming"
It's not GPU's that get maxed out with Vista, its the monitor outputs.
With Vista, Windoze sees 3 monitor outputs per 9800GX2 card, a DVI + a HDMI + a DVI connector in that order.
So with only 8 monitor outputs max in Vista, Windoze sees 5x DVI + 3x HDMI outputs and its only the DVI outputs that FAH uses to fold on.
Hence only 5 cores working.
If Vista only sees one monitor output from a 9800GTX/GTX+ card then you could add 2 of them to 2 GX2 cards for 6 cores running.
XP only sees the DVI outputs.
So with 8 outputs max, you can get 4x GX2 cards running.
I haven't run Windoze7 yet so I dont know if it follows XP or Vista's rules for the GX2 card outputs.
I have not yet got any 295 cards, so I don't know how many outputs each version of Windoze sees with them.
Luck ............
I think I've seen DIY guides for the HDMI dummy plugs
You should be able to dummy plug a HDMI. Go to monoprice get a HDMI to DVI adapter, then just shove a normal dummy plug on it.
That is unless the HDMI plug has no interface with the resistors though all those adapters. (might very well be the case)
