DVI - Different Types of cables
mokkapoop
Ok. I just bought a 7600GT at Fry's. I dont have a DVI cable. I do have an LCD with DVI, but do I know which kind to get (dvi-i, dvd-d, etc). It will be a male to male, so thats a given. What do I need to get?
You can use a dual-link, but your monitor won't use it unless you're running a 30". A single-link will work just fine. But yes, DVI cables are all DVI-D. It's the ports that are different.
Strictly speaking it won't use it unless:
a) It's enabled on both the video card and the monitor
b) the monitor can display greater than 1920x1200 pixels (or thereabouts*)
Size is not a factor.
*The actual pixel count varies with refresh rate. Basically single link bandwidth is 2.3Mpixels @ 60Hz and dual link bandwidth is 4.0Mpixels @ 60Hz
