Question on the two different types of DVI interfaces. My video card (Leadtek A250 GeForce4) has a DVI-I output according to its spec's but the LCD monitors - Samsung 930b and Sony HS95P both say they have DVI-D inputs. I've heard the DVI cables can be a little pricey and was using that to partly justify the higher cost of the sony - but if I have a DVI-I interface on the video card does anyone know if the included cable will work? or for that matter if the two styles are compatible?
Thanks,
Thanks,
