Stevo said:Theres 3 types of DVI ... DVI-D DVI-I and DVI-somethingelse
DVI-D is digital only so you cant connect an analogue CRT to it. DVD-I is DVI-Integrated or something and you can use both digital and analogue with it, the other is analogue only so I believe. All support different resolutions and different refresh rates. maybe somebody will be able to explain it better?
