Hello everybody.
I have a small problem,and i have no idea how could i fix it.
I purchased a new monitor,Samsung T240HD.Everything it's ok under windows,but when i run Linux ,i just set the native resolution which is 1920 * 1200 ,and my monitor start to blink every 30-40 seconds.Every Linux distro,even LIVE CD's.Anyway...
The cable is DVI D Single Link on monitor,and DVI D Single Link on videocard.
When i change the cable to DVI D Single to videocard,and VGA to monitor,everything it's okay under Linux,no more blinking on monitor,but i don't wanna switch to DVI-VGA because some people said,DVI-DVI has better signal ,and so on,but honestly i DO NOT SEE ANY DIFFERENCE.
The cable which cames along with the monitor,is actually DVI-D Single Link (both ends),but the slot behind the monitor is /support DVI D Dual Link.
Now i have few questions,i hope i'll get some help here.
1) Should i buy another cable? I mean DVI D Dual Link ? If the answer is "yes",please tell me what about the other end of the cable,what goes into the video card.DVI-D Dual Link as well? The videocard is PNY Nvidia GTX 285.Someone told me that would fix my problem under Linux.
2) Should i try HDMI (monitor) to DVI videocard?
3) What's the difference actually,between DVI-D Dual Link and DVI D Single Link?
4) If i leave it DVI - VGA,would i have some disadvantages? I mean colours /image quality /
sharpness / clear image / would be worst with DVI -VGA than DVI-DVI ?
I'm sorry for so many questions.Any advice is welcome.
Thanks in advance.
Thanks in advance.
