DVI Cable for Westy 22" LCD
For those of you with a Westinghouse 22" LCD Monitor, do you use a DVI cable? If so, is there a noticible difference between DVI and VGA on this monitor? Is it worth it to buy a DVI cable?
samven582 said:
will that work on my 9600XT?
Don't see why it wouldn't; most 9600XT models have a DVI-out port. Check to see that your monitor is DVI capable and you'll have a winning combination. :D
Cheers,
JP
