I have a NEC 17" flat panel (it's been around since 2002) and it only has 1 VGA port, my new graphics card has dual DVI, so I will be using a converter.
my question is, is the quality much different DVI vs. VGA? where will i be seeing the biggest difference in, when i use my LCD? should i bother upgrading to another 17/19?
also, i see people with 2-3 screen computer setups, with dual dvi i assume i can set two screens up? how would i do 3 screen setup? 2 graphics cards? can you do 4 screens with 2 dual dvi?
