DVDXCOPY isn't working...
Asazman
So while it's reading the DVD, about half-way through, I get a prompt to "END TASK" from windows, and forces me to close it out. I've troubleshooted quite a bit...but can't figure it out.....
I have a Sony 4x DVD-RW
Thanks!
i used to use dvdxcopy platinum 3.2.1 untill i got sick of all of the problems with my sony dru510a.
I would get random errors, coasters, and all sorts of things. I tried reformmatting several times.
I just got sick of it and swithced to using dvd decrypter, dvdshrink, and nero for burning. Using this combo i have yet to have any problems, plus i get a lot more costomizable options.
The only downside is that its not a one step burn.
edit: also doesnt this belong in the software section, i bet youd get more responses there
I say forget XCopy(I did after having to many problems) and go with the following....
DVD Decryptor
DVD Shrink
(Burning program of your choice, I use Nero5.5)
that is all I use and I love the fact that I can include ONLY the things I want.
They can all be found here----> www.dvdrhelp.com along with a lot of information.
I use the above to back up my DVDs and I use Fair Use(also found on dvdrhelp) to convert 'em to DivX and keep 'em on my computer(largest is about 800MB)
DVD Decryptor
DVD Shrink
exactly
DVD Decryptor
DVD Shrink
Also not a bad choice, I use both.
