DVDO VP50 firmware v1.09
Discussion in 'Home Theater PCs & Equipment' started by sprak74, Oct 7, 2018.
  1. sprak74
    sprak74 Gawd
    864
    Jun 11, 2007
    Just acquired dvdo vp50 from ebay and was wondering if anyone here has firmware v1.09 that they can sent me? I've tried the one off the internet that I found, but when I updated it, it says the file is corrupted. Thanks.
  2. Verge
    Verge [H]ardness Supreme
    6,111
    May 27, 2001
    Do you need a new firmware?
    You will probably have to ask around on AVS for one.
  3. sprak74
    sprak74 Gawd
    864
    Jun 11, 2007
    Thanks. I'll give it a shot.
  4. Verge
    6,111
    May 27, 2001
    If they fail try http://www.curtpalme.com/ forums. He used to sell and service them and alot of the old crt guys on there had them.
  5. MacrossPlus
    MacrossPlus n00b
    10
    Nov 8, 2011
    I found what you are looking for. If I remember correctly, you need an actual DB-9 port on a computer to do the upload. The USB to Serial converters have issues.
  6. Verge
    6,111
    May 27, 2001
    oh yuk. You are probably right though, i've had tons of problems with usb->serial for legacy stuff. Off to goodwill to buy a w98 laptop :)
    What did you theater look like? This was pretty high end stuff back in the day.
  7. MacrossPlus
    MacrossPlus n00b
    10
    Nov 8, 2011
    I work in the A/V industry. I used to use these to scale everything to the native resolution of the display. Most early LCD/DLP projectors had strange native resolutions or had issues switching from interlaced to progressive and back. I could set all of the inputs to the best native resolution, and then scale the output to the native resolution of the projector. I currently do this with Crestron who sells Digital Matrix Endpoints that have a scaler built in. I can also grab edids from equipment and ask for the correct resolution/format for the destination or upscale to the native resolution of the display/projector.
