Hi guys,
If anyone uses dvd x copy, generally how long does it take to burn the image to your hard drive? Then, how long does it take for you to burn the dvd? My friend has a 2.4x burner and can copy a dvd in like say 25 mins. I have a 4x sony burner and it takes me an hour to copy dvds. Then another hour on top of that to burn them. I can burn data dvd's quicker than this. I was wondering if it was the software that takes so long to copy the dvd or if it was something with my hardware.
Also, let me know if you are using the regular version or platinum.
thanks
-Stewie
thanks
-Stewie
