dvd-rw not reading dvd's
gordon151
I recently just installed an inactive dvd-rw (IO-Magic IDVD16DL) into a new system I just setup and for some reason it isn't reading dvd's. The dvdrw detects fine and it can read any "CD" i put in there, but once I shove a dvd in there it just reads it as a blank 4gb cd (even asks me if I want to write to it). Not sure what to do as I used a lens cleaner, then a duster (compressed air can) to rid of any dirt inside system, made sure it is connected correctly to motherboard and checked all the jumpers. Could it the dvd-rw just be defective? Any help is appreciated.
Try a disc you know is good in a different drive, then put it in this drive. Also, make sure that you uninstall any Nero software you might have, because InCD can be finicky about DVDs (sometimes). Further, make sure your drive's firmware is up to date (check the manufacturer website for "firmware")
Thanks for assistance Sovereign, shortly after posting this I thought up the whole firmware thing and that was indeed the problem. Funny thing is it was working before fine when I had it installed a couple months ago, maybe between then and now while in the closet something happened to the firmware :/? Everything works ok now, yay :D.
