dvd player won't read vcds....
[H]otspringtamago
my dad has a panasonic something or other dvd player that's supposed to read vcd's.
the problem is that, when i put tv shows i record on my computer onto vcd, they won't play anymore on his dvd player. it worked in the past though.
i've tried using a standalone decoder and encoder to put it into vcd format and then put it onto a vcd using nero. i've also tried using sonic primetime, but neither method works.
any help or advice you guys can give me would be greatly appreciated.
thank you!
p.s. it's a panasonic dvd-rv22 if the model number will help with any troubleshooting.
how fast are you burning the disk?some older dvd players hate stuff over 12x
The laser may be wearing down :(. Try some laser cleaning stuff or try better branded CD-R and slow burn speeds.
