Either your system region settings are incorrect or the optical drive is set for the wrong region.
Check your rig's settings in Control Panel -> Region and language settings.
Check the drive's setting in Device Manager. Right-click the drive and choose 'Properties'. You need the correct setting on the 'DVD Region' tab.
