DVD Duplicator - Looking for one
jgoewert
I'm trying to find a decent DVD duplicator for work.
Basically, I need one that can do small runs of around 10 disks at a time with the least amount of human intervention.
Basically, about the closest I found to what I want is this one from NewEgg - http://www.newegg.com/Product/Product.aspx?Item=N82E16827196115
With so few reviews, it is hard to tell if the two 5's are trolls for the company or the 1 is a troll against the company.
There are also these:
http://pro-audio.musiciansfriend.co...5disc-CDDVD-Duplicator-wHard-Drive?sku=620775
http://pro-audio.musiciansfriend.com/product/Acronova-Nimbie-CD-DVD-Duplicator-100-Disc?sku=580034
Below $1000 is the range I am shooting for. Any suggestions?
i've never had any experience with dedicated dvd burners... but i did burned over 1000+ dvds not long ago. my solution was simple. a combination of internal and external usb dvd burners with software that supports parallel burning like roxio.
5x of external usb Samsungs for $41.99 each at newegg [here] = $210.00
repeat twice and you got 10 dvds in less than half an hour!
or just load your existing computer with 4 internal dvd burners, just repeat thrice to get a dozen copies. i recommend $27.99 the nec/sony optiarcs [here].
save your company money and be a hero :rolleyes:
