I keep getting Error Reading Data whenever I burn DVDs or CDs lately. I'm using Nero 5.5.10.56. It doesn't matter if it's CD-R, DVD-R, or DVD+R. Here's the last few error logs;
1st
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 1/29/2003 9:37:36 PM
Nero Version: 5.5.10.56
Recorder: <_NEC DVD_RW ND-2510A> Version: 2.19 - HA 1 TA 0 - 5.5.10.56
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 1
CD-ROM: <_NEC DVD_RW ND-2510A>Version: 2.19 - HA 1 TA 0 - 5.5.10.56
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
DiskPeripheral : MAXTOR 6L080L4 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : _NEC DVD_RW ND-2510A atapi Port 1 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST CD-RW GCE-8160B atapi Port 1 ID 1 DMA: On
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523276kB)
Free physical memory: 205MB (210408kB)
Memory in use : 59 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: Off
7.1.2008
ISO compilation
8:13:46 PM #1 Text 0 File Isodoc.cpp, Line 7604
Iso document burn settings
Determine maximum speed : TRUE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 2 (Max. of 31 chars)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
8:13:46 PM #2 Text 0 File Reader.cpp, Line 115
Reader running
8:13:46 PM #3 Text 0 File Writer.cpp, Line 125
Writer _NEC DVD_RW ND-2510A running
8:13:46 PM #4 ISO9660GEN -11 File geniso.cpp, Line 4571
First writeable address = 0 (0x00000000)
8:13:46 PM #5 Text 0 File Burncd.cpp, Line 3773
Turn on Disc-At-Once, using DVD media
8:13:46 PM #6 Text 0 File ThreadedTransferInterface.cpp, Line 672
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 2278784 (2278784) = #2278784/506:23.59
relocatable, CD pos for caching/writing not required/required, no patch infos
8:13:48 PM #7 Text 0 File DlgWaitCD.cpp, Line 229
Last possible write address on media: 2298495 (510:46.45)
Last address to be written: 2278783 (506:23.58)
8:13:48 PM #8 Text 0 File DlgWaitCD.cpp, Line 234
Write in overburning mode: FALSE
8:13:48 PM #9 Text 0 File DlgWaitCD.cpp, Line 1703
Recorder: _NEC DVD_RW ND-2510A, Media type: DVD-R
Disc Manufacturer: CMC MA - G. AM3
Disc Application Code: 64, Disc Physical Code: 193
8:13:48 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 824
Prepare recorder _NEC DVD_RW ND-2510A for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 372289536
8:13:48 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 672
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2278784 blocks [_NEC DVD_RW ND-2510A ]
8:13:48 PM #12 Phase 24 File dlgbrnst.cpp, Line 1655
Caching of files started
8:13:50 PM #13 Phase 25 File dlgbrnst.cpp, Line 1655
Caching of files completed
8:13:50 PM #14 Phase 28 File dlgbrnst.cpp, Line 1655
Speed measurement started
8:13:50 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 1978
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
8:20:57 PM #16 TRANSFER -25 File Reader.cpp, Line 348
Error reading Data
8:20:57 PM #17 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
8:20:57 PM #18 Phase 30 File dlgbrnst.cpp, Line 1655
Speed measurement failed
8:20:57 PM #19 Text 0 File Scsicmd.cpp, Line 406
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 5/19/2006 4:16:24 PM
File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 3/7/2007 6:51:00 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 8/4/2004 12:59:42 AM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
2nd
Windows XP 5.1
IA32
WinAspi: -
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Free physical memory: 88MB (90720kB)
Memory in use : 82 %
Use Inquiry : 1
Wizard: Off
29.12.2007
ISO compilation
10:46:58 PM #1 Text 0 File Isodoc.cpp, Line 7604
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
10:46:58 PM #2 Text 0 File Reader.cpp, Line 115
Reader running
10:46:58 PM #3 Text 0 File Writer.cpp, Line 125
10:46:58 PM #4 ISO9660GEN -11 File geniso.cpp, Line 4571
10:46:58 PM #5 Text 0 File Burncd.cpp, Line 3773
10:46:58 PM #6 Text 0 File ThreadedTransferInterface.cpp, Line 672
10:46:58 PM #7 Text 0 File DlgWaitCD.cpp, Line 229
Last possible write address on media: 2295103 (510:01.28)
10:46:58 PM #8 Text 0 File DlgWaitCD.cpp, Line 234
10:46:58 PM #9 Text 0 File DlgWaitCD.cpp, Line 1703
Recorder: _NEC DVD_RW ND-2510A, Media type: DVD+R
10:46:58 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 824
DAO infos:
MCN:
Tracks 1 to 1:
10:46:58 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 672
10:46:58 PM #12 Phase 24 File dlgbrnst.cpp, Line 1655
10:47:01 PM #13 Phase 25 File dlgbrnst.cpp, Line 1655
10:47:01 PM #14 Phase 28 File dlgbrnst.cpp, Line 1655
10:47:01 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 1978
10:55:10 PM #16 TRANSFER -25 File Reader.cpp, Line 348
Error reading Data
10:55:10 PM #17 Text 0 File ThreadedTransfer.cpp, Line 222
10:55:10 PM #18 Phase 30 File dlgbrnst.cpp, Line 1655
10:55:11 PM #19 Text 0 File Scsicmd.cpp, Line 406
Existing drivers:
Registry Keys:
3rd
Windows XP 5.1
IA32
WinAspi: -
Recorder: <_NEC DVD_RW ND-2510A> Version: 2.17 - HA 1 TA 0 - 5.5.10.56
CD-ROM: <_NEC DVD_RW ND-2510A>Version: 2.17 - HA 1 TA 0 - 5.5.10.56
CdRomPeripheral : _NEC DVD_RW ND-2510A atapi Port 1 ID 0 DMA: Off
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Free physical memory: 113MB (116228kB)
Memory in use : 77 %
Use Inquiry : 1
Wizard: Off
28.12.2007
ISO compilation
9:30:23 PM #1 Text 0 File Isodoc.cpp, Line 7604
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
9:30:23 PM #2 Text 0 File Reader.cpp, Line 115
Reader running
9:30:23 PM #3 Text 0 File Writer.cpp, Line 125
9:30:23 PM #4 ISO9660GEN -11 File geniso.cpp, Line 4571
9:30:23 PM #5 Text 0 File Burncd.cpp, Line 3773
9:30:23 PM #6 Text 0 File ThreadedTransferInterface.cpp, Line 672
original CD pos #0 + 2217760 (2217760) = #2217760/492:50.10
9:30:24 PM #7 Text 0 File DlgWaitCD.cpp, Line 229
Last address to be written: 2217759 (492:50.09)
9:30:24 PM #8 Text 0 File DlgWaitCD.cpp, Line 234
9:30:24 PM #9 Text 0 File DlgWaitCD.cpp, Line 1703
9:30:24 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 824
DAO infos:
MCN:
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 247312384
9:30:24 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 672
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2217760 blocks [_NEC DVD_RW ND-2510A ]
9:30:24 PM #12 Phase 24 File dlgbrnst.cpp, Line 1655
9:30:27 PM #13 Phase 25 File dlgbrnst.cpp, Line 1655
9:30:27 PM #14 Phase 36 File dlgbrnst.cpp, Line 1655
Burn process started at 8x (11040 KB/s)
9:30:27 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 1978
9:30:27 PM #16 SCSI -1066 File Cdrdrv.cpp, Line 1243
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0767C000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0C 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x24 0x00
9:30:27 PM #17 Text 0 File DVDPlusRW.cpp, Line 474
Start write address at LBA 0
DVD high compatibility mode: Yes
10:01:42 PM #18 TRANSFER -25 File Reader.cpp, Line 348
Error reading Data
10:01:43 PM #19 Text 0 File ThreadedTransfer.cpp, Line 222
10:02:16 PM #20 Phase 38 File dlgbrnst.cpp, Line 1655
Burn process failed at 8x (11040 KB/s)
10:02:16 PM #21 Text 0 File Scsicmd.cpp, Line 406
Existing drivers:
Registry Keys:
1st
Windows XP 5.1
IA32
WinAspi: -
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Use Inquiry : 1
Wizard: Off
7.1.2008
ISO compilation
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
Reader running
DAO infos:
MCN:
Tracks 1 to 1:
Error reading Data
Existing drivers:
Registry Keys:
2nd
Windows XP 5.1
IA32
WinAspi: -
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Use Inquiry : 1
Wizard: Off
29.12.2007
ISO compilation
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
Reader running
DAO infos:
MCN:
Tracks 1 to 1:
Error reading Data
Existing drivers:
Registry Keys:
3rd
Windows XP 5.1
IA32
WinAspi: -
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Use Inquiry : 1
Wizard: Off
28.12.2007
ISO compilation
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
Reader running
DAO infos:
MCN:
Tracks 1 to 1:
Sense Code: 0x24
Sense Qual: 0x00
Error reading Data
Existing drivers:
Registry Keys:
