DVD Burner & DVD+R cd question
Coolguy123
I have a TDK indi DVD + - / + - RW DVD Burner... 12x DVD+R... 8x DVD-R...
Anyways. I got some dvd's dunno what brand they are possibly Comp Media Blank tops 4.7gigs up to 4x speeds. I've written to other dvds before with this burner, so i dont think its the burner. But with these CD's i have i try to write to these other DVD's and i cannot get it to open or see what i wrote to the dvds? I use Nero to write to the dvds. It writes to it. Nero says disk written successfuly. Then i try to read it and nothing is on the DVD?
Whats the problem? Dont tell me the DVDs are not compatible with this burner!
does it not work in your computer or not work in your home dvd player? alot of media wont play in stand alone players
Sounds like bad media. Nero is pretty good, you can always see the data even if the disk is not finished. See if any other, better media do it.
What kind of burning are you doing exactly? I've noticed than if I start a multisession burn I can't see anything past the first session I burn on the disk. Nero shows it as being there but the system itself can't see it. Not really sure what's up with it and I tried burning multiple times with several options and they never came viewable to anything except nero. I was using a plextor and nero with some memorex disks.
Out of curiosity what version of windows are you running and do you have all the patches installed?
Im using Windows XP Pro. WIth SP2 installed.
I tryed burning the cd multi layer and without multilayer. I cannot read the dvd either way.
