dvd backup
hyunee
Anyway before I backup my dvds to a blank media - can I save them to my hdd? How would I go about doing this?
Sure can. I would recommend DVD Decrypter for ripping them in any case. Check out doom9.org for some guides if you need them. If you're ripping a single-layer disc, you'll probably want to just use ISO read mode, if it's dual layer you'll probably go for File mode (for recompression or transcoding later, to fit on a blank disc).
Cool I just did that. I have a ~7gig dvd backed up on my hard drive. The file is huge! It has all those _TS files and what not. My question now, how do i burn this onto a blank dvd?
I usually just use DVD xcopy xpress to burn them onto disk. I don't see where i can use it to burn from disk. It just asks me to insert DVD.
Look into DVD Shrink. Same basic results, but you should have more control and input options and no little messages inserted into your backup.
