I did the heat gun fix on my motherboard a total of four times. Three myself and paid someone the first time. Each time temporary, including now. I told myself after it goes again, I wouldn't go through the effort of disassembling the laptop to temp-fix the motherboard and that I would buy a used laptop before it goes out again. Well, it went out again and I didn't buy a replacement computer to use. You can say out of aggravation or just not caring anymore, I gave up...almost.
If I could get it to boot one more time, I could just have it running all the time until I purchase a new laptop, but how without taking it apart? Well, I took the laptop, put it in a bunch of supermarket vegetable bags and grocery bags and sticking that pain in the ass in the refrigerator where I left it overnight. Next day when I went to go get something to eat, I saw it sitting there just chilling, literally. I completely forgot about it. I took it out of the bags, plugged it in, and IT WORKED! It booted straight in, I didn't even have to hit the keyboard a couple of times when the hp logo came up to get it to progress. I couldn't believe it.
But after shutting it down after a couple of hours and trying to boot up again, no go. It wouldn't post at all. So back in the refrigerator it went and when it came out, it booted just fine again and now I'm typing this up from that computer.
I must warn though that quite a bit of condensation builds up on it and it takes a while for the laptop to get warm enough to evaporate the moisture.
One thing that I would do differently if I have to shut it down again and it wont boot up is to take the hard drive out before I put it in the fridge and put it back in when I'm ready to boot the computer. So far I've done it twice but no damage done to the hdd, fortunately.
Is this common knowledge and I'm just speaking what everyone knows already? I did a quick google and hardforum search for "dv2000 refrigerator" but I didn't come across anything. If anyone has a laptop with the same problem and wants to boot it up and get data off of it one last time, this may be an option. If anyone else tries this, and isn't afraid of voiding your warranty any more than it already is, post your results.
