p0intblank said:Get a can of compressed air also.
(cf)Eclipse said:i use q-tips for my zalman, easier to get inbetween the blades than a finger![]()
101 said:If you own computers, you should also own an air compressor. Pays for itself after a few uses, as canned "air" is extremely expensive and the tree huggers will protest on your lawn if you use it too much. You can never get rid of that petulie oil stench, so you're really better off with the compressor.
