duron applebred results
Knucklez
hmm
i think something is fucked up here, im overclocking a 1.4ghz duron applebred to 1300mhz(as far as this shitty cheap ass mobo for 5$ from some kid, Pc Partner, or soemthing like that) anyways CPU-z is reporting my cpu VCORE being at 3.5!!!
my proc i sactually being uderclocked somehow while everything else is being overclocked, intriguing.... :-/
pics of proc to come soon
o anyone know where i can find the guide to unlocking the l2 cache and the pin mod guide in english at?
HERE IS THE INFO
DHD1400 DLV1C T8163270569
MIVGA 0346UPMW
is the l2 unlockable?
what about a pin mod?
:-D
any tips and hints would be appreciated...
btw 1gig of pc2700 ram samsung
UPDATED
after playing with some jumper settings on teh borad(the little tawtwaffle had the jumpers set to 100mhz fsb..dumbass) and some playin around in teh bios i got taht on a shitty as cooler master aluminum heatsink running very stable and much faster.
if anyone has any other tweaks/mods i could to do it, ur imput would be greatly accpeted....
EDIT: wtf is up with my vcore tho...it shouldnt be that high...im gettin nervous, anyone elses vcore that high(the bios has no option to change the vcore :-/)
i dun think there are any wire mods fo rthis board...
its a Pc Partner, no model number on teh board or in the manual.,....so i dunno
it may be reading the 3.3v line instead of the vcore or something. what voltages are reported in the bios?
what are the temps like? i highly doubt the vcore is actually that high... probably just a shitty motherboard with shitty readings.
it may also be reporting 2x the real vcore (1/2 of 3.5 is 1.75, so that would be about normal)
if the board doesnt support the duron it will fuck things up.. mine was detected at 1.2 at first. it says its a duron when it boots up but couldnt detect the speeds, which was just fine for my needs:D
:D
wow man, niiiice, i do believe it is jsut a shitty mobo with shitty readings, and the temp runs at about
50c in an antec case...
it flies, cant wait to mod it into an athlon
im using an epox 8k9a7i and even tho ppl claim the pci/agp busses arent locked i havent had a problem, and i even have a raid card. i personally thnk they are.
hehe i know what you mean
not to bad, what was ur default speed, mine was 1400, i wish i could mod mine into an athon, gimme a link for guide?
mine is a 0436
6 weeks after most of the moddable procs were made :(
think i could still mod it?
google, i dont have an exact link. mine is one of the middle ones- its moddable but its multi locked. default is 1.6 for me but i might sell mine and get a 1.8 and see what it can do. i doubt you can mod it but its worth a try.
it's worth a try, if i fry it, only 40$ for a new one :)
anyways, all the guides i found were in german or soemthing. Anyone have an English guide link?
kthx :)
thanks much, i think ill hold of till i get my other comp to mod this one incase i kill it :)
